So I browsed the offerings for rear sway bars from all of the vendors I previously mentioned and have narrowed it down to either Hotchkis or Firm Feel.
What I like about Firm Feel's setup is that they show photos and describe the install location as "frame hung". The ends mount with 4 bolts on each side at the leaf spring mount location with the U-bolts going through these mounts and also bolting the leaf springs to the axle. The inside mounting location bolts to the frame rails. It tucks up there nicely ABOVE the rear axle.
The Hotchkis website looks like it doesn't install as nicely as this and I don't think their's is frame hung. It looks like it's bolted to the axle with separate u-bolts and sits BELOW or at level with the rear axle, but maybe I'm not looking at the photos correctly in their install instructions.
Can anyone confirm this one way or the other that there is a difference in how Firm Feel and Hotchkis mount for the rear sway bar?
The other determining factor is I have a Hotchkis front bar that is 1-3/8" diameter (sorry, I said 1-1/8" earlier). The Hotchkis rear they offer is 7/8" which is about perfect. The Firm Feel rear bar offered is only 3/4". Will this 3/4" Firm Feel bar be big enough in conjunction with the Hotchkis front? If so, I'm going for the Firm Feel rear sway bar. Pricing is similar.
