Secret Chimp
I just pulled the intake off of my 318 (gaskets were leaking coolant) and found that a hole about an two inches down inside of the front coolant passages (this is the driver's side) had hard pebbly debris hiding in it.
The wider section of the passage and the intake itself are clear. Is this a secondary passage that's plugged up, or just some casting cavity that's filled up with gunk but doesn't flow anywhere? What's the best way to get this stuff out without pulling the heads Both times I've drained the system recently no funny junk came out.
