carpet install on a 73 charger
Randy73
8:34 PM
Florida
Tryng to install carpet in my 73 charger, need help in 2 areas.
How high up does the carpet go, i.e. do I need to cut out around the gas pedal or does it go just below?
Anybody got any pointers on how to install the carpet where the hump meets the rear seat pan
what kind of carpet do you have? 1 piece / 2 piece?
I installed carpet in my 74 this spring and I believe I had to make a cut at the pedal in order for the carpet mold for the 4 speed hump to square up.
I had a 2 piece and the back half was premolded for the footwells so that was no issue. I may have had to make cuts to fit the seat latches in the rear is all.
I can certainly take some photo's tonight if that helps.
John
It is 2 pieces and the back half was not molded, thinking now I bought from the wrong place.
Was the seatbelts and seat bolt holes already there and was the carpet cut for the center console?
hmmm
No, I had to make the cuts for seat-belts, cut hole for shifter and had to do plenty of trimming on the sides.
I really cannot comment on your carpet but I'd say you will have to resort to some glue if it isn't pre-formed so that it lays tight to your floor.
Perhaps others can chime in on it.
