67 Belvedere question
Tommyboy
12:11 PM
Oklahoma
I'll be simple and brief!
Can you use 67 Belvedere 4door body parts to replace the: fenders, rear wheelwell spots, quarters, and trunk extensions on a 2door hard top model?
Thank you for your time!
Ryan in Oklahoma
The front end parts, fenders, hood,etc. will swap. The wheel lip area should be the same, the area in front of the rear wheel opening won't be the same legnht, but should match up to the piont it stops at the rear door.Quarterpanels will be different. I would think the panel behind the wheel opening and trunk extension, would be the same. Take some measurements and compare the parts on the parts donor. Good luck
Here's a pic of a quarter patch from a 4D, used on a 2D.
You can clearly see the outline of the 4D "dog leg".
That's my brother in law's car, and I helped cut out the patch from the 4 door.
Ryan in Oklahoma
The trunk extension are the same for 4dr and 2dr.
does anyone have the two small chrome clips that are on the rear top of the drip rail on the 67 belvedere i have lost them and thats all i need to finish the paint job thanks dan 502-609-2102
