426 Oil Pan swap out
Rusty
8:09 PM
Texas
Guys - need some help. My 66 Belvedere II Hemi Car oil pan (Summitt# 30760) rubs hard on the steering cross link - I had to remove it due to a leaky gasket and want to put on a period ocrrect that doesnt rub as well as the associated correct oil pick up. Anyone know of a supplier and correct part numbers?
Pan again
Im looking into this pan do you think it will resolve my issue?
EBAY: 66-74 Mopar B E Body Cuda 426 Hemi 440-4 440 Six Pack 6 Quart Oil Pan Item Id: 400286434004
thats the one i'm talking about.
You shouldn't have a problem with either pan. Check your motor mounts to see if they are too soft thus allowing the engine to sit lower in the chassis. A good clue is to look at the fan location relative to the shroud (assuming you have a shroud) should be pretty centered.
