john.thompson068
Testing viscous fan/engine runs too hot at idle.
My motor will run as hot at 230* if it is just sitting there idling. Often it will run at 210-220* when stuck in traffic. As soon as the car is moving it runs at 160-180*. I ran the following test on my fan. The fan is an 18" MP viscous fan. It is the same fan as seen in the picture below.
With the engine cold, I went to spin the fan and it spins freely with very little resistance. I warmed the car up all the way to 212*. Several times I stopped running the car and went to spin the fan. It still turns freely with very little resistance even when at 212*. The fan is spinning very fast at idle and is generating a lot of air movement across the entire engine. I increased RPMs to like 3 or 4 thousand from under the hood, and the fan really picked up speed. My very short hair was getting blown straight back so it was really moving some air. I then grabbed a piece of cardboard and folded it up and used it to try and stop the fan while the engine was running. The fan did not stop spinning and started to chew up the cardboard.
My fan was purchased new and is low mileage. Is there something wrong with my fan?
The rest of the cooling system consists of a 20x18 radiator, it is the biggest one that will fit in the car. I only have 2" to spare on either side of the tanks. The opening in the support is the same width as the cooling surface of the radiator which is 20" across. If you add in the width of the tanks, the radiator would be a 24". You can see it has an aluminum water pump, and a fan shroud kit. The thermostat is pretty low mileage, but I have no idea if it's a 160* or 180* because it was so long ago I replaced it. The rad stays full of coolant almost to the very top and has a 19-21lb Moroso cap. The motor is your typical pump gas 550 hp 440. There is a B&M trans cooler sitting in front of the radiator on the front side of the radiator support, but it is small and covers less than half of the radiator.
Looks like I may have to buy a small pusher fan for the front of the radiator on that one side. Eventually, when I install air conditioning, their is some kind of cooler thing for the air conditioning that goes in that same spot as the trans cooler. So later I will have to buy one of the long skinny trans coolers and mount it underneath the radiator to make room for my air conditioning condenser unit or whatever that things is.
