Gas cap tech
62savoywagon
5:18 PM
Ridgecrest Ca.
Hey Gang
My '62 Savoy Wagon has no gas cap. I found a locking cap laying on the back seat (no key of course :mad:). I'm reluctant to shove it in the hole, as with no key, I wouldn't be able to get it back out!
So, does anybody out there have a photo of what a correct fuel cap (locking or not) looks like for my car?
If the cap I have is the right one, then I'll fork over the dough to get a key made.
At the moment, this is the only pic I have of the one I found...can you tell where it sat for 16 years? LOL! (in case you can't see it, it's by the seatbelt, upside down)
Gas cap
I looked at caps on AutoZone & NAPA. There are caps there, however it says ( Exc. Wagon.) Part numbers 11646 and 10646.
Try taking your lock cap and compare. Advance had them also.
Good luck.
since the caps off maybe you could pull the pins out and go to the hardware store and find a blank key that fits. wouldnt need a cut with no pins and no one would know but you.
Hey Gang
Rob,here is the correct cap.Also the cap from a 67/71 Dart is the same.Not sure ot the other Dart's.
That is the correct cap in the pic (same as a 63-66 A-body) 67-71 won't fit. Will be loose as 67-69 dart are a bit deeper where it goes into the filler tube. Will take pics tomorrow if you like. 1970 & up are different again (have 4 tabs instead of two)
Stant G27 was a replacement cap with the S-bar as the handle. Don't think they are avail~ anymore though...
63-66 Valiant, Dart or Barracuda cap is what you are looking for.
This is the cap that is on the wagon now,from 70 Dart Swinger.
Thanks Guys
I did find a set of keys for the gas cap that was on the back seat...it does fit, however the rubber gasket is petrified! Any way to soften it up or replace it?
