Al K
- 7:06 PM
- Nov 15, 2009
Will original '64 axles mate up with a 489 case Sure-Grip,as far as splines go? The original r&p have noticeable play,and since the car's up on stands for brake work,I may as well look at replacing the center section. Which means I'll be looking for another 489 case for the 3.91 gears I planned to install next year.
Along those same lines...are these axles strong enough to handle a strong 440 and a 2500 stall converter? When I go to the track(down the road),I'll either run a set of used street tires or maybe narrow drag radials. I'm using HD springs and will have a snubber for now;S/S spring may be considered later,if they're needed.
As always,thanks for any help,guys!
