- 10:31 AM
- Mar 10, 2010
- Hanover, Pennslyvania
That's The Brakes!
i did that mee meep. already been down down that road. even adjusted it in a little also just to be sure. still same issue. plus if it was to far out wouldnt i feel it hitting the plunger on the master when i put it back on
I use "Sil-Glyde" brake lubricant. It is a for contact points and the rubber boots and O-rings. It is non-melting too. Available most everywhere.
Yeah, i have used that stuff, works great
well im having the same problem right now only on my front disc brakes. mine just arent releasing. went 5 mile today and stopped and smoke was just rolling off my front discs. cant push the fluid back in the master cylinder with the line on from the caliper. took the line off the master cylinder and it pushed right in. put it back on same thing. cant push the piston back in. take it off and there it goes pushes nice and easy.
