Engine swap?
Small Block
12:07 AM
West Plains, Mo.
Think 62 plymouth belvedere post car. Now has a 318 poly setting between the fenders. I have a 413 with str 14 cross ram that will be going in it. What will need to be changed? What motor mounts will i need? Any cutting or changes to the K member? I don't know so i thought it wise to ask. I'd love to have original exhaust and will be looking for a pair of max wedge heads. For now tell me about the motor swap please. BTW i'm Small Block over on A bodies. Thanks
You are able to buy mounts for that to change over.No cutting or welding to K member
Easy swap.They used two V/8 K frames.The early had a seperate bracket that bolted to the K frame and the motor mount bolted to the bracket.The other had the mount bolt directly to the K frame.Either will work.
Will Schumachers have the mounts you refer to? Wonder if any vendors at MMW will have what i'm looking for that comes to mind? You guys got any leads on a pair of exhaust manifolds or big heads? You can take a look at my starting point on the motor over at A bodies under general . See MMW, 4 th page.
You can probably find the (BIG Heads) on either Moparts or e-bay
The exhaust manifolds are Big Bucks
:eek:ld_school:
Thanks Mark; Those repops will fill the bill, now for a set of heads. I'll check ebay and anyplace else i can think of.
Hey Mark: I clicked on the Tonys thing and can't seem to find the head you were refering to. Any suggestions?
Here ya go:
1964 parts for sale: 1964 426 max wedge orig 518 heads bare, nice shape, no
damage, but have been slightly cleaned up in the intake ports, but no damage or
cracks or any welding or seats or stripped-out holes; valve covers; 1964
original max wedge crossram intake; 3705 carbs; $3,500.00 for the complete set
up. Parts are in Muskego WI Contact John -- JANDLWALTERS_AT_SBCGLOBAL_DOT_NET
(Replace the _AT_ with @ and the _DOT_ with . to email the seller.)
