green440duster
Hey guys need some help here; first the back story: My 727 was working perfect then I decided to add a Turbo Action 3000 stall converter and put my 3.91's back in. Did that and road tested great, then I ended up blowing the rear servo backing out of the garage, frustrated and thinking it was my reverse band I sent out my spare 727 to be rebuilt with a Transgo stage 2 shift kit to a local guy.
So when I get the tranny back and installed it is shifting weird in drive shifts from 1-2 only after you lift the throttle at about 5 grand!! then 2-3 shifts at about 4000 and no downshift (either passing gear or slowing down) but will if you manually pull it down a gear or two. Now in manual it has a huge delay and sometimes won't shift from 1-2 unless you go to drive instead of 2nd not very impressive when you hit the rev limiter thank God for MSD I have played with kickdown (lokar cable) to no avail (worked fine with old trans). I am going back to see tranny guy but would like to know Mopar thoughts first because this guy does mostly chevy work.
Jamie
Jamie
