Sweet5ltr
Need help deciding what is the best cam for my application.
440 (451ci) 11:1cr.
Victor 440 single plane
Proform/Holley 750 (flows 820+)
Performer RPM cylinder heads (84cc)
833 four speed.
4.10 gear, 30" tire.
Currently am running a Comp XE285HL but feel it is too much for the stock stamped rocker arms. Switching to an adjustable valve train so I might as well switch to a solid cam.
Was looking at the MP .557. How does this compare to other solid lifter cams in the .550 lift range or hydraulic flat tappet camshafts? Don't want to switch out stock valve springs, and idle quality or vac. for power brakes, etc. isn't a concern.
440 (451ci) 11:1cr.
833 four speed.
