I thought it was the other way around...pin until 74, slider after that.
My 72-74 cars all have pins, but my 87 5th Ave had sliders.
they used both into the 80's
i have a set of pin caliper brackets off a 78 cordoba
that will match up with the larger 11 3/4 rotor
and it will all fit under a 15 inch tire.
the pin brackets are not easy to find for the larger 11 3/4 rotor
more often you will find the sliders..
the only rotors you can get reasonably priced now
are the 10.87 and the 11 3/4 rotors.
also those rotors will only fit a spindle
that is 73-up
unless you use an adapter for the bearing.
they do offer smaller rotors but they are pricey
you need the correct caliper bracket to match the rotor size
the type of caliper has no bearing on the rotor size.
i have been collecting parts for a disc brake conversion
so i did a bunch of research before i started matching up parts :grin:
