- 8:21 PM
- Jan 16, 2011
- NorCal Sierras
I don't want to get overly technical here, but scaling your car with 4 separate scales with you in it or preferably some weight, so you can see the scales or get a competent helper to record the weights for you & see what each corner actually needs, after getting the proper pinion angles &/or prelaod, for actual spring & shocks, it's the best way to know what spring rate is required, I would suggest moving the battery to the pass. side rear of the trunk to help offset the driver weight some, it helps weight transfer a ton it's like adding {2-2.5 lbs} for every {1 lb} you take off the front, when it goes to the back, especially when the weight is forward of the front axle/spindles &/or farther behind the rear axle the better weight transfers, Example = move 40lbs battery is equal to 80-100lbs of ballast when removed from the front & added to the rear & cleans up the engine bay also... Just my thoughts.... There is a decent book from Mopar Performance Like $30.00 "Chassis 9th Edition" Part #P5007160, it has some great formulas & combos for basics & expected performance etc., there are better books, but for your needs & expectations or combo, that's plenty I would think...
