cr8crshr
- 11:51 PM
- Feb 13, 2009
- Northwest Nevada
That is not what I asked. I don't want to read a book, and I don't need an advertisement ABOUT that book ---- and I might just have that very one. I want to know how YOU are doing it, and what steps you took to make CERTAIN that the cam lobes were on the backside (heels) when you set them.
If you are using the Hughes method, this IS the so called 90* method:
http://www.hughesengines.com/Upload/productInstructions/ValveAdjust.pdf
and also matches the Mopar chart:
As I said before, I use the EOIC method, because then I don't have to worry about firing order. That method works on any engine from B&S to Pratt & Whitney, as long as it's 4 stroke and has poppet valves.
Easy there "COWBOY"...I don't need to be lectured about what I am and am not using for my situation. I merely stated what processes I have been using and the 180 degree process comes out of the book I used for my builds. It was not meant as an "ADVERTISEMENT". And good for you if you have the book. I have also used the 90 degree methods from both Hughes and MOPAR. The results have been pretty much the same regardless of the 180 or 90 degree method. The EOIC method is foreign to me at this stage of the game. And please define what you mean by "backside of the cam lobes" as I have not encountered that procedure or description any where???? 4 stroke I get and understand but "poppet valves???? Not all of us have the Plethora of knowledge that others here have....:jerk:
