Hemirunner
When you get into the 4.250/4.375 stroke stuff, the cranks are more rigid. I think between that and the better bearing selection, I'm willing to accept the trade off in bearing speed. I know what you mean on the program caps, that was a pain although I was using a rottler F-67A so it was a little easier...Made the thrust a real easy procedure.Speaking of line boring the B engines...don't you hate what Program Engineering did to the billet cap they make now? When you buy them for the RB engine, they sell you a cap that works for both B & RB engines so you have to bore the ever living hell out of them...they just cut the bearing tang deeper so they cover all the engines with one part number. Man, it takes forever...
I have never bored a 383/400 to the bigger bore. I usually build these combos for high rpm use and I like the slower bearing speeds with the small bore. I have always wondered if the crank is more rigid with the larger bearing though...the bearing selection is a bonus, I'll give you that.
