Viper Six speed Tranny ? will it fit in a 70 b body ( SuperBird)
Some cool **** there. Maybe some day I can get my car to shift by hand.
Your stock speedo will not work with a T6060. You will have to get a T56 magnum to get the speedo gear. On a T6060 it is electronic. There may be a motor that can use the electronic signal from the viper T6060 and turn your speedo or you can go aftermarket electronic speedo.
yeah hopefully i can find a speedo that will fit in my rallley dash , I'm ok with changing just the speed part if i can find one i like the looks of . Scott my buddy thats helping me said something about a box that get the signal from the sensor and then turns the cable ? but that sounds like a pain
You'll need to run an electronic speedo - also I doubt the shifter location will be anywhere you can use a stock console - with the 5-speed I put in mine I used the rear mount and modified my console to match - no one has realized it is not a factory position or factory shifter hole.
well i pulled the trigger and bought the viper tranny today
drove 1/2 way to omaha and met a guy in the mcdonalds parking lot to get the viper 6 speed
let the games begin
viper tranny crossmemberphoto(50).JPGone small step closer
Good morning Stuart -
Here is a photo of the components that I can provide. I just noticed the the cross member hardware is not shown, which is included. Let me know on these.
Prices are
Cross member - $199.00
Hydraulic Master Cylinder Mount - $ 79.00
Line set and fitting - Earls - $29.00
Tilton Master Cylinder - $ 75.00
Includes all the reservoir options shown.
American Power train had 10% off today for cyber monday
so i called and ordered the rest of my stuff
Customer Description of Car:
1970
make = Mopar
model = RR
engine = 440 6 pack
hp_torque = 450 hp
tire_size =
flywheel_tooth_count =
current_transmission = Automatic///Viper T56
rear_end_ratio = 3.54 Dana
console = Yes
seats = Buckets
request for =
0.00 0.00
ISGM-20002 ISGM-20002 GM ISO-X Transmission Isolator Mount for GM
TKO, Magnum, 4-Speed and 700R4/4L60e.
DSUN-30004 3.5" .120 Aluminum Driveshaft, includes cryo treated slip yoke
and cryo solid u-joints, specify length, yoke type and u-joint size
when ordering
1 449.00 449.00
FWCH-10001 FWCH-10001, SCIENCE FRICTION Billet Steel Flywheel, SFI
Quality, 130t/10.5", Chrysler 6-bolt, Neutral Balance, Big Block,
318, 340 and CB 1972-73 6-Pack 440
229.00 229.00
BHCH-28073 BHCH-28073 - QT SFI Bell Housing, Chrysler Big Block/426
HEMI to Viper T-56, 130t fw only
539.00 539.00
CLCH-12203G SCIENCE FRICTION 107523C MEAN STREET STAGE 2
KEVLAR CLUTCH KIT, INCLUDES:
HIGH CLAMP LOAD LOW FLEX FORMED PRESSURE
PLATE,
23-SPLINE FULL FACE KEVLAR SPRUNG HUB DISC,
STAINLESS PILOT BEARING,
ALIGNMENT TOOL,
535 FT-LB RATED,
LIGHT
FSGM-10001 #910 GM/Mopar Pressure Plate Bolt, Set of 6, Race Grade 8 18.00 18.00
FSGM-10002 #912 CHEVY/MOPAR/FORD FLYWHEEL BOLT, SET OF 6,
Race Grade 8
15.00 15.00
Subtotal ------->> 1,699.00
Discount WD WD Discount for American Powertrain dealers: (Speedway) -175.00 -175.00
Shipping Shipping and Handling 75.00 75.00
Page 3
