- 4:17 PM
- Jan 16, 2011
- NorCal Sierras
great thread I love a great debate...LOL...
Wrong again I'm afraid...
This is what I diagnosed this morning. With the key turned on, I'm only getting a little over 6 volts to the coil. When disconnected from the coil, I get 13 volts at the positive lead. I scraped all the grounds to bare metal. I have good continuity from coil negative back to the box and from the box frame to engine ground, but open between the coil negative and engine (body) ground (with key on). This leads me to believe that the control box is faulty, maybe fried it by using Accel coil? Now I realize I skipped a step and will check from the box terminal through the box to ground. The box is new but 30 plus years old.
:BSMeter:I didn't try to belittle anyone, I simply stated you are incorrect. You don't SPEAK like anyone who has a degree in anything.
The discharge of a CD/ photoflash is EXACTLY relevant to what happens in a Mopar ECU/ points fired ignition. The coil stores energy, discharges the field, and charges the cap. The cap discharges to the coil, and the two oscillate. THIS IS AN EASY TO PROVE FACTOID
The parallel IS that the cap stores energy and helps the coil to BUILD THE SPARK
For any of you readers who DO NOT BELIEVE this is true, and happen to have ANY engine which runs a points fired system, simply remove the condenser and see how well it runs. Uh.....It won't.
I'm not trying to impress anyone. I'm simply trying to explain that you CAN NOT CHECK A COIL under what might be called "simulated operating conditions" without a condenser/ capacitor. It simply will not build the spark as it does when installed in the system.
I think the words of your post speak for themselves. You are now trying to tell me I'm the troublemaker, when you keep insisting on posting incorrect information. I haven't called you any names, or belittled you in any way. I'm simply telling you that your statement about testing a coil IS NOT RELEVANT.
...You cannot test a coil by the method indicated. It WILL make a spark, but NOT a good spark WHY is that? Because these types of ignition systems MUST HAVE a condenser (capacitor) in the circuit. If you for example, remove the condenser from a points type distributor, the car generally will not start. The Mopar ignitions basically have a condenser built into the box...
My guess is that you have a mismatch between the ignition box and the Accel coil. The ignition box must be able to drive the current that the coil requires, otherwise the spark will be weak.I'm still waiting to hear my newly rebuilt 440 run for the first time. Everything has been checked and double checked but she won't start. I pulled number one plug out and grounded it and it gets a small orange spark but nothing that looks like it will knock you on your butt or fire under compession. I have a NOS ignition box and electronic distributor, new forward conversion harness and new Accel coil, wires and plugs. Any ideas???
