Endangered Species
Well, I a couple of weeks ago I was getting ready to back the rockers off, but before I did I wanted to check the lash and leak the motor down. So I rolled the motor over to TCD and checked #2 int. it was fine, then I checked # 8 exh. (UHH OHH) I had over .050 lash. so I rolled it over and leaked it.... 0... now I knew it wasn't good. That's when I looked and found metal in the lifter valley.
to make a long story short we pulled the intake and found the cam had a chuck taken out of it but that was about it.
We then took the heads off, and everything looked fine.
Well last night we pulled the short block out and put it on the stand. As I was pulling the pan off I noticed the convex dent in the oil pan... I knew we were in trouble. when I lifted the pan off it sounded like a box of rocks. and that's when I seen the carnage.
He broked #8 rod. It took the cam, crank, pistons and we have some niced gouges in the cylinder... at least that what I can see so far.
Hopefully the block can be fixed, we won't know that until we get the rods and crank out. The Crank, Rods and Pistons are junk. How the head didn't get hurt god only knows.
