electric choke wiring
tpodwdog
Banned
Banned
6:28 PM
pittsburgh pa
hi guys....great news. the 66 charger is ALIVEEEEEEEEEEEE...got it running today......anyhoo, theres an electric choke on the 383. looks to be a carter. theres 2 leads on the choke housing.....one dead center.....one off center. which one is the positive and which one is the negative ????? heres a pic............. 006.jpg
Doesn't matter. Hook the power up the the center and ground to the other one. Or not. Check for any markings on the housing near the terminals. They may be marked + and -
should be a slight width difference between the connectors so it should be obvious how they connect
theres no markings on it. i kinda figgered it didnt matter but i didnt want a fire. thanx guys!
Guessing the car most likely had the old type choke setup so its not wired for a electric one so no wires.
wiring it in is not a problem since i totally rewired this car over the past 3 weeks. i just wasnt sure which was the pos(+) or if it even mattered. i can pull 12v off the run side of the ballast....or the pos(+) of the coil...it dont matter there. my only question was if anyone knew which was pos(+) and which was neg(-). thanx a million!
either way will work fine.i normally try to stay away from the ignition feed and pull my power from something else.i have heard of people having issues with even minor voltage drops in the ignition hot leads.(some on this site.)
Probably doesn't matter. On one of my cars with a Holley with this choke, I have the left grounded & the right wired into a "switched" circuit.
I've always taken the intial power off the ballast and have yet to experience any problems
From a trouble shooting Book.....
Simply using a switched power source, especially one that is hot in the ACC position, can cause the choke to open prematurely if the key is on but the engine is not running.
There is no relationship between the actual temperature of the engine and the operation of an electric choke. The choke operates as a function of the time that current has been passing through the internal element. This means that you want to connect the lead to a wire that is energized only when the car is running. In a rough sense, this means a wire that is connected to the IGN terminal of the ignition switch. Note that this isn't completely correct; if your car is stalled, the choke will continue to open because the IGN terminal is still energized even when the car is not actually running. As a practical matter, however, I think it's a moot point.
You should also note that an electric choke is nominally calibrated to be used with a 12V system. This would imply that you shouldn't tap your coil wire, as it's only ~9V when the car is running. That would be unfortunate, as it allows a neat, out-of-the-way tap. However, there are two possible exceptions to this:
If you have bypassed the resistance wire to your coil (e.g. after installing a Pertronix setup) so that you always have 12 V at the coil.
If the choke has enough adjustment in it to compensate for the slower operation at 9V.
In addition to tapping the coil wire, there are several other options for providing power to the choke:
You can tap the wire to the transmission shift switch.
You can also tap the blue (stator) wire from the alternator harness. This wire is energized only when the car is running. Given the routing of the alternator harness and the size of the air cleaner, you can make this tap very neatly as well. I don't believe that this will have any detrimental effect on the operation of your voltage regulator. The stator wire doesn't do anything except energize the field relay in the regulator. These relays typically don't require much current, so I'm guessing that you *should* be able to safely tap the stator wire. If I'm wrong, it will obvious, as the field relay won't close, which means the alternator light will stay on while the engine's running.
You can run a wire from terminal 4 (brown wire) of the regulator. Although this is the most direct connection to the IGN terminal, you'll have to route the wire clear around the engine compartment. Cosmetically, it's the least desirable option.
You bought that car? Last I remember you were wondering what was a fair price for the drunk dude? wow you now have a literal barn full of cars and now you suck cuz I'm jealous!
no BIGMAN i didnt buy it. just helping a friend get it going. we fired it up the other day after it sitting for 7 years after the rebuild ( i didnt rebuild it). he just didnt know how to get it going. so i spent 3 weeks rewiring almost the whole car. it was very exciting to have got it all dialed in before the initial start.......pre-primed it....... dialed in the dizzy....poured a little gas in the carb....and it instantly fired up and runs like a beast. 90% of the wires on the bulkhead connector in the engine bay were cut......hadda trace em all down and rewire. THENNNN....wired in a Mopar electronic ignition......got it all right the first time and she sprung to life. i was expecting a major fight with the ignition, but the Mopar gods wanted that car running, and now it does. thanx for all the help guys!
