- 1:28 PM
- Nov 22, 2010
- Muroc Dry Lake Bed
Lately there have been questions on 8 3/4" rear ends that "one" can purchase thru local salvage yards, etc. Question of compatibility, length and what vehicle they came in. Here are a few things I have found to help me when searching for a rear end. Hope this helps someone. I just bought a rear end and it was not compatible. Now I know.
REMEMBER: if it was made before 1964 the axes were tapered and the axle flange assemblies were held in place by the use of a KEY and LOCKNUT configuration. (like my 1963 Max Wedge 741 housing)
Best to search for the 2070742s (742s) used from 1961-1969 and used the 1 3/4" diameter 10-spline pinion shaft OR the 2881488s and the 2881489s, used from 1969-1974 and were the only cases used after 1972. Pinion shaft diameter: 1 7/8" with the either a 10 or 29 spline.
Rear end housing widths used on MOPARs. (NOTE: All measurements are from brake drum to brake drum)
1966-1972 A-bodies: 57 1/8"
1962-1963 B-bodies: 58 1/2"
1964-1967 B-bodies: 59 1/2"
1970-1971 Imperial: 59 3/4"
1968-1970 B-bodies: 60 1/8"
1970-1974 E-Bodies: 61 5/8"
1965-1969 C-bodies: 61 3/4"
1965-1970A100 vans: 61 3/4"
1965-1966 imperials: 62"
1967-1969 Imperials: 62 5/16"
1970-1971 C-bodies: 63"
1971-1974 B-bodies: 63"
1965-1971 D100 trucks: 64"
1969 C-body wagons: 64 3/8"
1971-1973 B-body wagons: 64 3/8 "
1970-1973 C-bodies: 64 3/8"
1972-1974 D100 pickups: 64 3/8"
