OK, so I've got a couple of things going on here...
The 451 motor build is about to get underway again and hopefully finish by summer. I'm going to run a carb for now, but still have plans to upgrade to EFI in the future, so fuel delivery is key and EFI requires an electric fuel pump. I was going to just stick with the Carter mechanical fuel pump, but California fuel eats up the rubber inside and I also plan to add an A/C compressor from Buchillon that fits where the Carter pump is at instead of the big bulky up-top compressor, so the Carter pump needs to go.
I would love to have an electric pump if I could find one that is not noisy (not less noisy, but actually QUIET). The only way to do this that I've been reading about is to have an in-tank submersible pump like modern cars do.
However, a submersible pump in an original fuel tank from 1968 will have fuel starvation and cavitation problems since these tanks don't drain from the bottom and the pump at times may not be completely submerged.
What this is leading to is I was going to replace my fuel tank anyway, so why not get one with a submersible pump?
I know Spectra is a recommended tank supplier and I'm going to call them tomorrow. Thought about Airtex too, but I don't know if they make tanks. Does anyone know of any good turnkey tank/submersible pump/fuel pick-up setups that will fit our cars? I would like to avoid moving the tank to inside the trunk if possible.
