How to i d a 727 trans for big block 440 eng.
moparjohnny
11:01 AM
ga
I need the wisdom and eyes of many. Thanks
ANYONE HAVE A PIC OF THE SET UP HOW IT WILL LOOK ON TRANS WITH HOOK UP?
THIS IS FOR 67 CORONET.
So what is your question exactly? How to ID a big block 727? Simple. There are four converter cover bolt holes in the bottom of the bellhousing instead of two like on a small block 727.
I would highly suggest you buy a 1967 Dodge Factory Service Manual, lots of photos & detailed instruction, for band adjustments, shifter linkages & Throttle Pressure Valve/Kick Down linkages etc..
