Propwash
- 10:23 PM
- Oct 29, 2009
- Island of Misfit Toys
Hey Fella's.....
Engine guy did a mock up on the upper end of my 512. While trying to install the Billet Petronix Distributor (w/ Vacuum advance) the distributor body and cap hit the front inner corner of the Eddy head. I know some guys have run into the same issue with some of the MSD distributors. A little work with the die grinder and they can get them to slide in. Questions are: Anyone here running or tried to run the Petronix Billet Distributor with aftermarket heads? Is it even possible and if so, how much shaving is needed on the corner of the head? I don't want to go on a big excavating mission and end up screwing up a perfectly good set of eddy heads I poured a bunch of money into to accommodate a distributor that cost lest than 10% of the eddy's and the port/bowl/valve work done on them.
Also, what other distributors fit with no/minimal clearance work? I really wanted to stick with the Petronix, but if worse comes to worse I have no issue posting a For Sale ad here on FBBO. I do want to stick with Vacuum Advance though.
Thanks for your time
