Propwash
- 11:42 PM
- Oct 29, 2009
- Island of Misfit Toys
Hey Gent's,
Figured this question would more suite the racer's on this board. Here's my scenario; I'll be running a bypass fuel regulator on the backside of the fuel log tied onto my quickfuel Q950. Pump is a clay smith 6 valve mechanical 140GPH (non regulated). A) In this system, should my return line be the same size as the feed line? B) My fuel sending unit (located about mid tank) has a return port adjacent to the fuel feed port. I read the return line should come back in at the top of the tank. Would it work to just run the return line to the sending unit return port or go ahead and modify the tank to have a return port at the top? The return port bends down 90* inside the tank, seems like you would want the fuel to come back in that way to prevent fuel being shot down into the tank, causing it to bubble up/foam.
Thanks for the help. :notworthy:
