I want a set of Indy 572-13 385 cnc ported heads badly.
SUPERSTOCKRACER
Oblivion
That flow upward in the 425-430 cfm@.900 lift
I'm wondering how much more hp I can make compared to my 572-13 365 cc heads that only flow 402@.900 lift
I'm on a quest to get someone to do a set for me.
the question is are you using the air flow you have now ? how much hp,cam lift,how bad does the intake hurt the flow?
Call INDY
a good rule of thumb supposedly is 2.06hp-2.35hp per/CFM of added flow, maybe as much as 61.8-70.5HP more "possibly" with the right compression, intake, bore size, camshaft & valve size/valve-train, headers length/size combo
Good questions. To the list I would like to add..........cubic inches?...........RPM?
1041 hp@6700 rpms, .828 lift(?) 440-25 inline indy crossram. goes 8.97 @151 and 9.04 in the heat.588 CI 15.5 compression.shifting at 7100 rpms.
I want new heads with a indy tunnelram with my 2 carter 750 AFB's
Call INDY
I will never call Indy.
Jim Laroy. Nuff said.
I need info on him, contact info. I want new heads and done.
send a pm to IQ52,I have a flow bench & have been porting heads for many years but for health reasons i am out of the business,i still do my own stuff it just takes me a lot longer time to do things. IQ52 [ JIM ] KNOWS what he is doing!
from the #s what you have is WORKING !!! to make any improvement, old & new heads & intake should be tested on the SAME flow bench.
I'm thinking the very same thing cdr, that is a very good engine.
All of our work is hand porting, we have no CNC machine. We've never ported an Indy 572-13 and have just briefly done work on an OOTB EZ head (313-327cfm @ .700") which we have flowing 370 cfm after our first tests. I have the 325 cc CNC Indy ported 440-1 heads in the shop right now. Out of the box, depending on which port you test, you get 361-374 cfm @ .700" and 368-378 cfm @.800" lift. I can't see why you couldn't get 400+ cfm from the 572-13 @ .700" and who knows what at .800" & .900". But again, I can't prove anything because we've not tested the 572-13, I'm just speculating.
LaRoy Engines in Challis Idaho, Jim & Cody LaRoy... I will let him give you contact information if he so desires to give it out... He knows his stuff, very knowledgeable, professional engine builders & head porters...
I guess you have a beef of some kind with Indy Cylinder Heads, for some reason, that I didn't know anything about... I suggested contacting them because they are the source/builder, to cut to the chase so to speak... but you could also contact Mancini Racing too, they may also have some heads ready to go....
Even the victors are capable of 400+ cfm. Cncport where I had my mw vics are getting over 400 off them. As soon as I get my valves and springs I guy I know is gonna do my valve job and see if he can flow them or maybe send them to get flowed. But like I posted on about my heads with just a 45 degree cut instead of the 50 yield over 400 cfm on them. Chck out their site cncport.com just need to buy tye heads and send them to them.
I'M WONDERING IF I GET A BARE SET OF THESE HEADS CNC PORTED FROM INDY, COULD YOU DO THE REST OF THE WORK TO GET THERM IN THE 420 CFM RANGE?
Do you do the valve job, and build them with titanium valves, retainers, pak triple springs?
i'k interested. thanks
Yes we can do the valve job and assembly them correctly.
Can we improve on the CNC porting? I believe so. Indy does a pretty good job of CNC porting but that doesn't mean it is perfect. I'd rather start with the unported heads or the 365 cc CNC heads as a second choice and lastly the 385 cc, but we would work with what you wanted.
I HAVE 365 CC HEADS ON THE CAR NOW.
i can get the bare heads if you want or if your a dealer,you can get them for me, i thought the 385 cc heads would flow more at the end of the day?
With the 385 cc heads, we can use titanium intake and exhaust valves which IIRC are good for a tenth over SS valves.
The seats in all the 572-13 heads are the same size, but titanium valves will sometimes require different seats in the heads other than the ones used for stainless valves. Some seats used with stainless valves are too hard for the titanium valves. If the Indy heads are using ductile iron seats we are good to go. The unported or the 365 heads may be fine, we just need to check with Indy.
I like to start with the heads that have the least amount of work done to them because I'm not convince that Indy has the heads ported in the best shape to begin with. I prefer to use my own design rather than try to modify someone else's. I've turned away porting jobs because someone else has already ported them and ruined some critical areas. It's ticked off a few people but I don't want my name on someone else's junk.
Not trying to stick my nose in here, but I have a valid question for the subject, I think. I have always been under the impression that hand porting (by a known good porter) was actually better than CNC porting. Am I out in left field with that? Just looking at a CNC ported head VS a hand ported one, the hand ported head has a much smoother finish. It seems that would lead to a head that flows better. Am I stupid?
I think starting off with a pair of CNC heads and then finishing them off by hand, blending bowls,etc would be the best way to make power.
But i'm still confused on why you think a 365 cc indy head would be better than a 385.
Len from Mancini racings 63 Plymouth has the same motor as mine but his heads are 385 cc ones done by jeff at modern cylinder head and they got over 425 cfm out of theirs.Which makes me think with a new set of 385 cc heads my motor could make more power and get me where I want to be with ET & MPH.
Your thinking is real close to correct. (But never end a paragraph with, "Am I stupid? It's too hard to work around that without saying anything that makes it sound like I agree with "stupid", because I DON"T think you are stupid.) I don't believe it is the finish of the surface Rob, as much as it is the port shape. The CNC port is only as good as the the hand porter that formed it before it was programmed into the computer.
In a previous life my sons and I were weldors. While working at a heavy equipment repair and construction outfit, the quality of our welds had a notable difference from those of other weldors. Soon we were hearing from those weldors, "Hey, you trying to make us look bad?".
Under our breath the return comment was always, "No, you're doing that all by yourself!"
Eventually the word came that my sons and I were to do the finish or cap weld passes so that the finished product would look better. That resulted in slower production and a less quality finished product. Why? We had to remove all the garbage from the fill passes in order to put a good weld on the surface.
What does that have to do with porting?
Hand blending a CNC port might be the easiest way to gain a "few cfm". (Or having your best weldors cover up some other weldor's junk will make it look a little better.) But what makes you think that the biggest CNC ported head is the best foundation for the most flow? (Or that junk weld fill passes are the best solution for quality finish welds?) Is 425 cfm all they are capable of? Maybe the CNC program is LIMITING them to 425 cfm because material has been removed during the machining that is required for greater flows. Why not 450 cfm? I have tested CNC ported heads on our flow bench. Never have they come up, on our bench, to the flows as advertised. We start with as-cast Edelbrock 440 RPM cylinder heads, hand port them, and they flow 348 cfm @ .700" lift. What does the CNC program get you? An "advertised" 320 something cfm?
Now the truth.
Can we start with an as-cast 572-13 head and make it flow 450 cfm?
I........DON'T.........KNOW! We've never had the opportunity to try.
There are some really good head porting shops out there. Are they better'n the guys in Challis? Most of the world thinks so...................
