71charger500
How do I tell what rear end my car has? It is a 71 charger 500 and has 10 bolts. Thanks guys.
Just keep in mind, if you intend to do anything, it's not a "cover" on that.. it's a "pig", which holds the entire differential.Judging from the picture guide above, it is an 8-3/4. It's round on the rear side, with no removable cover. The cover is on the front side, towards the drive shaft. Thanks, you guys are awesome!
If you want the 3rd member out you first must pull the axles... sometimes they are easy sometime you need a slide hammer. Then unbold the 3rd member and it will come out but be awair they ar about 75lb depending on SG and gears
