Multi Carburetor setups Besides looking cool.....
thomas93254
10:00 PM
BFE California
Is there any real benefit to multi carb setups? For example you can run 2 550 CFM carbs or one Holley Dominator 1050. Or lets take it a step down 2 two barrel 300 cfm carbs or one 4 barrel 600 cfm carb what would the benefit of the two over one besides the very cool factor?
Thomas
They sure do if the owner isn't willing to learn how to tune them.
hemirunner i agree with you. most people who are afraid of multi-carb can't tune a single carb. multi-carb combo's can be far more versatile than a large single carb.
Single carb works better on street. Multi carbs look nice. A really experienced pro can make a tri carb system run really well, but for most people that is unrealistic.
In many cases there is a lot of benefit from a multi carb set up. Just ask Porsche, Alfa Romeo, Ferrari, etc... Most of those foreign cars tend to get a lot of power from little engines and that's due to technology. However, in my opinion, the typical multi carb systems found on our familiar production cars was really to boost sales because of WOW factor, and the installation on these engines was more of an exercise to make the multi carb system work rather than using the multi carb system to extract more power. If you look at the NASCAR hemi what did it use to deliver fuel to each cylinder? Most likely a single Holley on a bathtub intake. 340 Trans am? Single Holley. Some exceptions to this rule are the race hemi and Max Wedge. Bottom line is I bet my 426 hemi can be made to run as good if not better with one properly sized carb on a proper intake.
i believe it was in '64 that nascar banned multi-carb set-ups; thus the single carb engines. the europeans and japanese used multi-carb set ups that used a venturi for each cylinder, something like the american IR systems. these systems had power advantages, especially in smaller engines. i think the greatest advantage for multi-carb in a street car is the ability to drive off a pair of small venturi's and have a staged velocity controlled set of large venturi's for WOT. large venturi's don't mix fuel as well at low air velocity compared to the smaller. in a race set up 2x4's on a tunnel ram type intake has been the king for decades.
the idea behind multiple carb set ups is to creat more even fuel distribution.never really developed well for street use.as others have said,it caused more tuning issues then power gains.in race applications it is king.fuel injection came along and stoped development except in restricted classes.take a look at pro stock nhra setups and you will see what i meen.
Meep is correct in that multiple carbs will perform best in some engines,but here are so many variables that you can't really make a blanket statement that multiple carbs or single carbs are the best for every application. Different engines for different uses need different things from their induction systems. As an example, dual Holleys on a big tunnel ram might be the best setup for a radical big block drag race motor, but not the same motor with a mild cam etc. driven daily on the street.
Everyone has their own preferences, but it's hard to argue with the coolness factor of multi-carb setups.
I run 2 4's on my 392 hemi with progressive linkage. Not only is the idle great but the off idle performance is smooth. The gen 1 hemis came with 2x4's from the factory. And when you step on it and bring in the other carb it to me out performs a single carb. Yeah, todays carbs and intakes can outperform the older intakes with multiple carbs as some testing has shown but on the street it is the feel the driver gets that matter. And have driven them all, tripower, 2x4's, and single carb I like the performance of the multiple setups when tuned right.
The only reason that most people hold this to be true is that most won't take the time to sort out a multi-carb setup.(Hell, most people won't take the time to tune their four barrel carbs!) A well tuned six barrel setup will out perform most single four combos on the street. There are limitations to every setup and I wouldn't try to run a six pack when it needs a dominator instead. Don't get me wrong, I love the simplicity of a single carb setup and I'm doing a single dominator hemi now, but there's nothing quite like a well setup multi-carb arrangement at full throttle!!
my '69 r/t picked up from 14.01 dead stock to 13.13 with nothing other than a six-pak. no performance cams, gears, converters or other gadgets. it's all about air flow. when discussing multi-carb with a single carb die hard it's like jack hammering concrete out of their heads.
I don't get why people are so intimidated by anything more than 1 carb ....I have a six pack and wouldn't trade it for a 4bbl ever performance wise or anything its just that much better for my application
Do sixpack big blocks really get better MPG if you stay out of the throttle? I know long ago that was one premise. Running off just the center 2bbl, when putting around town and not racing. I have no idea how/where in the throttle position, that it kicks in the outboards for the full 1300+ cfm. Guess I need to read more...
Mine are just for looks, they work and run fine though, I like the easy kind, Edelbrock. Good for beginners! 318 Poly 275HP enough for the convertible :headbang:
X2!
the mpg thing probably depends a lot on the driver. a 6-pak has the potential for better fuel mileage due to the small venturis of the center carb. smaller carbs atomize fuel better due to a higher air flow velocity. of course you have to consider that opening the end carbs is a little bit addictive.
thats a cool set-up! i love those old polys.
If anyone deserves creditf ro small primary carbs it would be rochester quadrajet. These ugly fugly carbs really where the best designed carb ever used. I tried them years ago on a hemi. I would never let anyone see it but i can tell you these carbs really operated really well. If i was road racing i'd give a legs for a set of weber single throttle carbs.
View attachment 127777View attachment 127778
Nice lookin ride.
It all depends on what the engines fuel & air flow needs are.... What goes in must come out, just a big air compressor... Depends on what the intended usage will ultimately be... If properly set up multiple carbs didn't work/run better/faster & do you actually think a NHRA Pro-Stoker or Top-Sportsman or Pro-Mod cars {or whom ever} would run split Dominators or Dual Dominators, on a custom sheet metal tunnel ram, if they actually thought a single lower manifold & big 4bbl carb would do better ?? I think not, because they can't & won't perform better... Again it really Depends on what the usage will be... Most cars should probably have a simple single carburetor on a moderate aluminum high rise setup.... But also most people, can't &/or won't, be able to "properly tune a carburetor" for performance anyway, let alone tune their way out of a paper damn bag either...LOL... IMHFO The NASCAR example is completely, different because without restrictor plates the single larger carburetor had better response in corners, it's the rules also, but the multiple carb setups had better top speeds... But mostly because of float position, weight & design or type of boosters &/or type of squirter's & accel. pumps... IMHFO it's just what air flow the specific engine can handle, or needs, the multiple carbs are just another tuning aid... Some setups won't make much, if any more power, allot of reasons why, than the properly sized & set up single carburetor, on a marginal engine combo, with some multiple carb set ups, may have also a slight tunnel ram effect, that will give some added HP/TQ, if properly tuned & sized for the engine combo... Cost &/or rules, also plays a very big part of single vs multiple carb applications also, in todays world, EFI or Mech. FI is the best way to go, but a well tuned multiple carb set up is very easily made street worthy, especially with all the trick carb stuff you can get today.... Cylinder head & intake Porting, valve size, proper valve springs etc. &/or the exhaust manifolds size/style vs header tube style, length, size, shape even & what size style length of collectors, or even ignition work or matched components, for your specific combo, is so much more important {to a point}, but people have these obsessions with carburetors, will cheap out on exhaust, cheap headers or no professional cylinder head & manifold porting work.... Opinions will Vary Vastly, I'm sure....
You've pretty well hit the nail on the head..... we've seen it all over the years. Big 500 inchers with dual planes, high compression, little cams and ported heads and little 1-7/8" tube headers, and 4.88 gears. Total combination failure......After a while you get tired of beating your forehead on the wall and just nod and smile when they tell you about their awesome combo.
