Hood Pin Location - 69 RR
Lamadogg
12:05 PM
Raleigh, NC
Looking to install hood pins on 1969 RR. Not lift-off hood - standard steel with hinges. Does anyone have factory specs on correct hole placement? Obviously, will not get a second chance so want to get it right. Will purchase from Year One and plan to get 25" tethers based on ther recommendation, part #A010025S. Also, where do the studs install as well as tether attachment under the hood. Photos appreciated.
Thx.
Thanks for link to 'Lift-off' forum. Though it took a while, I finally installed the hood pins. Rather than use the existing inboard radiator support bolt, I chose to use the A12 hole location and drilled the holes. I must have measure a dozen times before drilling the top hood holes! I feel the location closer to the front edge of the hood and looks better. Thanks again. They look great. See photo. hood pins RR.jpg
