Looking for suggestions and knowledge on the BB 727. I've got some leakage and I don't know if its the pan gasket or something else but the trans is leaking fluid. It's covering the whole pan and dripping and seems to have been for a long while. The car is a 68 Coronet RT, I have no idea when the filter or pan gasket was last changed. It's been sitting w/o starting since approx 2003 so I'm thinking even if it's not leaking from the pan gasket the fluid and filter need changed and I'd like to have a easier method of changing the fluid with the drain plug on the replacement pan.
Any suggestions on an improvement in the pan?
I've read a stock 518 pan is heavier duty, stronger, etc with more capacity but this doesn't exactly look like it fits ??. As far as the drain plug I could put one in I suppose. Don't know if filter extension required.
http://www.ebay.com/itm/518-618-BOT...pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
This one has cooling vent tubes but is pricey with the filter extension
http://www.starperformanceproducts.com/Mopar-A518-A727-Turbulator-Cooling-Transmission-Pan-14110.htm
Other things I'm thinking is something like this
http://www.jegs.com/webapp/wcs/stor...EAR=1522949&MAKE=1523433&N=1523452+4294966021
http://www.summitracing.com/parts/hup-hp1580/overview/
I'm definitely open to recommendations as to what auto trans owners have done or would do and what I should be thinking about including the fact the leak may be coming from elsewhere, but I'd like to change the pan, filter and gasket anyway to improve cooling w/o putting on an external cooler unless someone has a cool setup to recommend. I've seen them zip tied to the radiator and I don't think I want that look.
If anyone has one with straight pan rails they want to sell please PM me.
