Do not need to go to metal, right?
Inspector71
8:45 PM
Lee's Summit Missouri
One of my cars is a very faded UU1 blue. Most of it has no rust. I am sanding the engine compartment. As I understand it, minus rust or repair, as long as I have sanded the paint to a chalky flat appearance, I dont' have to take it to metal in order to prime and paint it. Is this correct? Also, in the few places I've had to go to metal, I don't see primer anywhere. Is that normal? Thanks
It depends. Over time paint can wear leaving primer exposed and moisture can seep under the primer and cause rust.
If all is well than yes you can, just pay careful attention to problem areas and look for swelling, blistering or any other signs. Using a sealer before painting is a good idea.
yep as the guys above point out if you have any weather checking or cracking you wanna get down to the metal, best wishes!
Thanks, Great advice and you are correct. In some areas the paint is faded and smooth and in others, it has bubbled, cracked, or stained. I am taking that down to bare metal like you advised. The good news is, once I do, I am finding good metal. I brought the car with me when I moved to the Midwest from the West Coast. Now, how do I tell people, when it i done, the massive "runs" down the inside of the fenders are factory? Ha ha
X2 on what 747Mopar posted. I would use epoxy primer to seal it off before top coating.
