cr8crshr
- 11:59 AM
- Feb 13, 2009
- Northwest Nevada
So now here is a new wrinkle on my 66 Sat build. We got the whole thing put back together with the new motor/engine. Just a brief run down. Old motor had a sever knock to it. Replaced it with a new re-built short block and swapped over all the parts except the bottom end to the new motor. The 1st motor had been broken in and had at least 10 hours of run time to it plus some street time.
With the first motor, the builder had set up the Cam @ 4 degrees retarded. The Cam is a Hughes Cam which is ground @ 3 degrees advanced so there really shouldn't be an issue here with that set up. Sprockets are aligned dot to dot and the chain installed correctly. Everything else is the same from the old motor to the new with the exception of a different carb. It wouldn't fire right away so I looked things over and could find nothing wrong or out of place. Bumped in a little more timing and tried again. It wanted to fire but instead we got a big backfire through the carb. This happened again after giving it some more timing. Now normally when it backfires through the carb the first thing to check is the 180 degree out equation. We were out so we corrected that. Still got backfire through the carb. Thinking that something might be screwed up, we put the motor back to TDC and pulled the distributor to check that and discovered that the key way for the distributor shaft was not @ parallel to the center line of the BB @ TDC. On BB motors the key way should be @ parallel center while on a SB the key way should be @ just up from parallel and facing towards the #1 piston or the first intake manifold bolt on the #1 side. This is per the FSM and Mopar Actions/EBooger's latest article on initial fire up. We then tore into the front end of the motor thinking that there might be something with the timing chain and or the gears. The timing gears were lined up dot to dot with the Crank sprocket set @ 4R key way. This is what was degree'd in by the first motor's builder. Once again other than the knocking, the first motor worked and ran. No matter how we tried to get the cam distributor gear to set @ parallel, it wouldn't do it. It would seat at either the 4-10 or the 2-8 position. Not parallel @ the 3-9 position if you are looking straight down into the distributor opening. I can see where that would be confusing. Good catch.I then referenced back to the first motor as I have been putting that one together with parts I have. The short block came already with a very tame cam and a single roller timing chain and gears so I put them into the first motor and they are aligned correctly and the same distributor put in to see if it would align correctly. The key way aligned parallel to center. With the new motor I don't remember if the single set up was aligned correctly or not as I didn't pay much attention to it when I was removing it. I plan on checking that out this weekend before I try this....
If I understand all this that goes into engine and motor building correctly, it is that even though we are not @ parallel center on this BB, we are OK as long as we have the motor correctly @ TDC and the #1 plug wire tower and the rotor pointing correctly towards #1. By this I mean that the rotor is contacting the #1 contact point inside the cap at the #1 plug post, and that the #1 plug wire is in the same #1 position, we then should be OK in the theory of it. As long as everything is lined up correctly in relation to #1 and we are @ TDC then it really doesn't matter where the distributor gear is placed or if it is off of parallel center line. Is this a correct understanding? I have been kind of analyzing this on my own and have been wondering if this is all that needs to be done to get this back up and running. Again in theory it should work fine. Jump in and discuss. Pictures are hard to get to come out clearly so written descriptions will have to do for now.
