pinkpanthr
So my 383 Road Runner sat untouched for 33 years before I bought it. The engine needed a carb, the old Carter was a total loss. I put in a new water pump, oil pump, fuel pump, and MP electronic distributor. Inspected the internals and they seem to be in good shape. (Cylinder walls smooth, etc.) The question is, when I start the engine it run fairly smooth but every few seconds it shakes, and acts as if it has a miss then smooths out again. Is a bit better when you bring the revs up but the problem is still there, just not as noticable. Anything obvious I should look for? Do the valve springs need to be replaced? At least a few of the set compressed for a long time. Thanks in advance.
