kdtjb
- 4:20 PM
- Jan 24, 2010
- In a van, down by the river,
Anybody ever try one of these? how did it work.http://www.summitracing.com/parts/edl-350801/overview/make/dodge
Installed Fast EZ multiport this summer. Competition Components offers a Fast EZ multiport kitAnybody got pictures and info on there f.I. systems, I have tinkeritis, and am thinking off taking the six Pac off of my 64 and putting f.I. on it. I like a clean look without a lot off wires every where.
http://www.buyracingparts.com/induc...-retrofit-kit-big-block-mopar-multi-port.html
This is a pretty good deal compared to alot of others.Installed Fast EZ multiport this summer. Competition Components offers a Fast EZ multiport kit
There is another member here that is really into the EFI and mega-squirt issue. His handle escapes me now, but if he see's this, he will chime in. EFI will NOT make gobs of power. The real gains will be slightly better fuel economy. A longer, flatter, torque curve, near perfect tuning for all conditions, easier starts. And the big reason I am a fan of it, No cylinder-wash-down like you get from a bad, or flooded carb! No more gas-filled oil. Back in the day when I grew-up, about 100k was it for a motor. I fully believe that FI is a BIG reason motors are routinely going 200k these days.
My plan for the BB in my Mope is a Mega-Squirt controller, fuel-rail with injectors per cylinder (not "throttle-body"), eliminate the distributor (will need a camshaft position sensor), and a bracket above the valve cover to hold a"coil-on-plug" set-up.
Am installing the Edelbrock Pro-Flo 4 on my 68 Charger. Greatest challenge thus far is the routing of two 5/8" OD fuel and return hoses, especially around the rear frame rail. Would appreciate if you'd share pics of your installation.Performance wise I haven,t noticed any big improvements, maybe a touch more bottom end.Idles smoother,mpg increased on long trips ,example: last year to Moparfest in New Hamburg used 3/4 tank of gas on a 140 mile trip one way,this year just over 1/2-5/8. I like the ability to set the air/fuel to maintain performance and economy when needed. Need to do a 1/4 mile run to see if gains were made, the car ran great before the conversion.
The efi harness runs along the drivers side valve cover, factory harness and msd on the passenger side.
