HELP: Loose stud in 8 3/4 housing
themechanic
Oklahoma is OK
10:08 PM
Moore, Oklahoma
There are ten carrier mounting studs. One stud wiggles a bit. First thought was to drive out loose stud and install with JB Weld. Any other ideas?
Thanks FBBO.
You could tack weld it, get new ones, or drill/tap it for a bolt. I personally wouldn't use JB weld on it.
NAPA or any good parts house will have replacement studs, maybe even in slightly oversized if the hole is buggered.
put new stud in, it should be good to go..I bet the old stud does not have any splines left
If the axle end where the stud goes is wallowed out you may want to replace the axle, cheaper than loosing a wheel while driving.
[video=youtube;15OMRX5scFU]http://www.youtube.com/watch?v=15OMRX5scFU[/video]
now imagine your on a two lane and you meet that in the oncoming lane
Sorry if anyone is confused; I need the carrier mounting stud not a wheel mounting/axle stud. Thanks for the replies.
Check with napa, eBay....dr. diff, jegs, summit, so on!
You can use a heli coil as a replacement...
Let me check around.....be back in a minute.
I found the backing plate studs, not sure if they could be used or not.
http://www.ebay.com/itm/Mopar-8-75-8-3-4-housing-end-stud-kit-with-nuts-3-8-24-thread-NEW-OEM-/171152810364?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d980a17c&vxp=mtr
If not, I'll knock one out of a spare housing and send it to ya, just let me know.
Also just checked moparts.com, and who would've thought of this.....a ferd 9 studs are a direct bolt in, but are just a tad longer. If you use those, I won't hold it against ya, lol!!
I'd zap it on the back side with a MIG or TIG. Just make sure it's super clean.
I'd do exactly what Meep's suggests here.
Otherwise gently tap the stud out and take it down to the local auto parts store, they should be able to mic the diameters and pick one off the shelf. They should be a pretty standard stud. Even if its not fine thread you can still replace it.
that should be a screw in stud,no access to back side.do like pops said and use a heli coil setup.jb weld is not strong enough in that way,do it right.
Splines look new on the stud. It was just wiggles a little from side to side.
Will save that idea in case all else fails.
I wonder why Dr Diff told me they are hard to find? He old me to use JB Weld.
I removed the stud, the splines look new. So, I put JB Weld on it and popped it back in. With 9 other studs holding and this one taking over 3000 pounds of force to brake loose (according to the JB Weld product specs), I think I'll be fine.
Thanks to everyone for your interest in helping me solve this problem.
I have no welder.
You were talking about the center section studs, right? They are screw in and can be bought at most auto parts stores under product name Help, Motormite, Dorman and many others.
I got some replacements for mine a few years back from Car Quest....in little bins in front of counter
there is nothing special about them....just a standard stud
I guess I assumed they pressed in like wheel studs, never took the time to investigate when I had mine apart since none of them were loose.
In that case, a touch of jb weld in there is probably enough to lock it into place.
The complete set:
Mancini racing Housing Hardware Package
Fits: 8-3/4
$47.95
MREHK8755
The ends only:
$29.95
MRE875850
Mancini racing
