BBishere2
Noticed that my '67 Coronet R/T - 440 V8 was a little low on coolant - so I poured in some anti-freeze - all the way up to the bottom of the opening under the radiator cap - after running the car for a bit - I started to get coolant coming out the overflow tube - since these cars didn't have a reservoir to catch it - I threw down some oil dry to catch it -
I see by the service manual that to do a pressure test, the coolant level is supposed to be about 1/2 inch below the neck - should that be about where I need to fill coolant to normally? I haven't removed the cap to see how much or how little is in the radiator now - it was just above the top of the plates in the core when I filled it up the last time -
I was thinking about doing a little modification to the brace for the battery tray closest to the radiator core support in order to put a coolant overflow reservoir in - any comments or suggestions along those lines?
Ordered the parts to replace the windshield reservoir/pump assy that was missing - found out that neither one came with the nylon nut/filter that holds the pump in - so I ended up ordering one and paying about the same in shipping as I did for the nut itself - something to look out for when replacing those!
Replaced the upper vent hose elbow that I thought was leaking - but still have the fuel odor around the back of the car - it looked like it was leaking from that elbow the last time I filled it up - but apparently, that didn't seal it - so I still have that problem to deal with - got to get that fixed before all else - don't want to blow up the garage - I don't think the little woman would be too happy if that happened...
Have a great weekend everyone!
