1966 Satellite Big Block Commando
robinsonwr
2:14 PM
Carriere, ms
front one piece complete.jpgWell guys thanks to AMD I have started the restoration of my 66' Satellite. I have been replacing interior sheetmetal from the front to the back.
Here are some pictures of the work that has been done so far.removal rear seat area.jpgrear seat area prep.jpgrear seat area fitment.jpgfinished cabin install.jpgfinished cabin install 1.jpgfinished cabin install2.jpg
looking good thanks for posting :headbang:
Excellent work. Would you mind posting pictures on how you have the car supported? I'm about to tackle my floor and cowl so I need all the help I can get.
I am currently waiting on my quarter extensions to come in from Sherman. Then I will install my AMD lower quarter patch panels. The bumper support or rear panel was cut out of my donor 67' Belvedere.
Well for the one piece floor pan first I leveled the car on jack stands. Once leveled I used screw stands along with 2 X 3 box tubing. After the one piece floor install was complete I installed weld in sub frame connectors and torque boxes from CarTool.
Thanks for the info ... I have 4 screw jacks that I planned to use to support the front floor pan area while doing the replacement. Did you run the 2 x 3 steel from side to side?
Also I saw that you had rust proofed the inside of your frame rails ... what product did you use?
Yes, I tacked the 2 X 3 to the frame rails to keep them from moving. The rust proofing product is POR15. It is some really good stuff I more or less removed one panel at a time from front to rear. Make sure if you do the one piece front pan to have friends help with fitment. Oh, spend the money on 1/8" draw clecos. They are much better than conventional spring clecos.
Floor and connectors look good in place. You've got a really good start on this.
Thanks roadrunnerman I am trying to get the car ready to receive the 512" stroker that will be nested between the frame rails. I hope to have the metal work complete by December so it can go to the body shop.
Well Christmas arrived early my Sherman quarter extensions came in yesterday. Look like pretty nice pieces. I hope they fit as well as they look. I will post pictures of them shortly.
The sherman quarter extensions I would not use because the quality was poor. I cut them out of my 67 Belevedere parts car along with other rear panels needed for the restoration. Should have more pictures shortly.
Well guys had a few days off for winter weather so I made the best of it. I got the rear of the car buttoned up now. I guess I will repair the rusty spots on the donor trunk extensions and install them next. I am getting pretty close to sending my baby to the body shop for some TLC and color.
67 donor part.jpg67 trunk extensions.jpgDriver trunk extension.jpgBumper panel install.jpgRear valence prep.jpgRear panel installed.jpg
Looks great, did you have to remove rear sheet metal to slide trunk pan in or are you able to place trunk pan in through trunk opening?
clemul,
Unfortunately it will not slide in through the trunk opening. I actually cut the rear valence enough to slide it right through the back of the car into place. I knew the rear valence had rust issues so it made it a viable option. AMD also makes a two piece trunk pan that I highly recommend. I did not want the seam to be visible.
Very nice work, all the surgery so far looks great. Really like the other car as well "not a huge Pontiac fan but always liked the Bandit cars".
I found my pictures of the car when I bought it. I paid $1225.00 for the car originally. The car was complete but in rough shape. The exterior trim was in place and the interior was there but had been ravaged by time and vorments.
104_0333.jpg104_0334.jpg104_0335.jpg104_0336.jpg104_0338.jpg104_0339.jpg104_0340.jpg104_0337.jpg104_0336.jpg104_0341.jpg
104_0332.jpg104_0331.jpg104_0330.jpg104_0329.jpg104_0342.jpg104_0343.jpg104_0344.jpg104_0345.jpg104_0346.jpgHere are the interior pictures. Please do not laugh. The car sat in a barn in Arkansas for thirty five years. The joop under the carpet sucked up the moisture and rusted the floor pans out. That is the reason I changed all the interior metal first. All I can say is Legendary will be getting my business in the near future.
really nice work so far! the welding looks top notch! and she was a rough one for sure!
charger360,
I always wanted a mopar since my dad was a mopar fanatic when I was growing up. My dad had a 1966 Satellite hemi four speed car. It was the only new car he ever bought. The car in the post is the same paint code and interior code as his hemi car. Of course mine is not a hemi car just a 361 big block automatic car. My dream is to transplant the elephant into the car and A833 18 spline tranmission. For right now a 512/440 with a forward manual valve body 727 will do.
