Grabinov911
- 11:04 AM
- Jan 27, 2012
- Southern California
Guys I just can't get enough air into my motor. It's a 493 stroker with stock Eddy RPM heads and a Quickfuel 850 carb. I bought a simple dropped base 14 inch by 3" high air cleaner to try, and the car is noticably slower than running with the huge 16" by 4" cleaner that i stuck on temporarily before i put the hood back on.
I was at a show(up) kind of event on Saturday and revved the engine with the hood up for a bunch of guys. Everyone said "Holy cow! That engine's gonna such the whole air cleaner in!"
I had someone rev it for me, and you can actually see the air filter fighting not to get swallowed!
All I'm using is a cheap paper filter. Do I need to go to a bigger diameter (16")? Or a different kind of filter? I can't really go any taller - already basically rubbing on the hood insulation. I don't think that one of those "filter top" type elements will help much as the top would be rubbing on the inside of the hood anyway - not likely to get much air through there.
Thoughts on high flow air filter setups for motors under a stock hood?
Thanks,
Greg
Thanks,
Greg
