383 "hp"?
Mr.Joshua
5:20 AM
Kennewick, WA
383 "hp"?
Hey guys. Wonder if anyone could help me with a quick question that I can't seem to get answered by internet searching my brains out.
Just got a new toy (project) in the garage and its a bit of a Frankenstein. Its a '68 Charger that was originally a 318/auto that was pulled in want of a 383/4-speed. I figured out that the tranny is a 1970 (7-17-1969) and the 383 is a '61 (9-28-1960). I got the initial motor ID from the normal block stamp. The other ID stamp right under the distributor reads R38-127 which means R=1961 and 38=383 while 127 is January 27th. But there was also a big "HP" stamped there and that obviously is High Performance. This site explains it a bit.
My question is what was done to these motors to get that High Performance stamp?
Funny enough, my dad used to own a 383 HP and, to his knowledge, they had solid lifters and higher compression. But I would really like to find something more definitive on what exactly was done at the factory to make the "HP" version of the 383 different from the garden variety.
Here's a picture, FWIW.
HP motors got different carb, cam, valve springs, exhaust manifolds, windage tray. Block and heads are the same as non-HP motors.
Thanks for the info so far. Next step is finding out what heads are on this thing. I'm totally new in the BB scene.
Was hoping for stock heads but in true Frankenstein fashion, these are 906 heads (2.08/1.74) from a 68-70 383/440. Maybe a tell that it was rebuilt at some point. Casting on the drivers side head under the valve cover reads 28439062 and 10127.
nothing wrong with 906 heads...probably the second best head out there next to the 915's
X2 A383.
Wow, you have an antique 383! The HP version is nothing too crazy except the dual quads. The cam was very mild - nothing like the Road Runner cam used in the late 60's.
Well then, good to know. Thanks.
X2 A383.
Yeah I know. When I first started looking into the castings and saw the the '60 stamp, I was a little shocked. My Uncle happened to be over at the time and his response was "I didn't even know they made 383s in 1960".
And it might be safe to say that nothing original remains on that engine. Does it have the iron adjustable rockers? Or stamped steel?
