1965 belvedere
hybrid229
8:07 AM
georgia
image.jpgThis is a one owner 65k original miles car. My plans are to air ride suspension, front disc brake conversion, 4 link rear end and some 18 inch Detroit steel wheels. Lightly sand car and flat clear it. Rebuild motor and tranny.
Sounds good. I vote for a turbo or two and a rear facing camera so you can record the looks on their faces when you send em packin.
Here you go this motor is for sale. street drive anywhere. 10.08@136 ,3.23 gear, 275 radials, full street trim.
Hell yeah! Bag it and drag it!! Fifth ave disc brake spindles will bolt up if you want to save some money.
Now that is a sleeper!!!
take the spindles from a fifth ave or diplomat with all the brake parts(rotor, backing plate, caliper bracket, and caliper) and using your factory lower ball joints you can bolt them right on! I used the fifth ave rubber lines but I had to tweak the hard line slightly to get it lined up right. Check out my build thread for pics and other info.
