Holley Carb Rebuilding
RS23VOA
1:56 PM
Virginia
Who do you use for your Holley Restoration work? I'm at the point i need to get mine done. Thanks
The biggest trick with holley is make sure you use the correct gaskets if carb was good just match them up and do not junk old ones till you are sure
and straighten the metering block if warped
A member on FABO also has done good work on carburetors, His screen name is rustyratrod (Rob).
