- 6:45 PM
- Dec 4, 2009
- Pasadena, Texas
Engine in question is a 440 with mildly ported 516 heads with 1.74 exhausts, 2.08 intake. Pocket ported and blended up into the ports, valve guide protrusion totally removed from exhaust side, intake side teardropped, Hemi grind cam, stock bore cast pistons (.050 down) with steel shim gaskets, 10.3-1 compression. Engine will see a 3100 lb car with driver. Transmission will be automatic with 3000 or so converter. Have an M1 on the shelf for a low deck and am thinking if it will work fine I'll make some spacers to fit it.
