- 12:00 AM
- Jan 16, 2011
- NorCal Sierras
swinging pickup hits the trap door, only swings 25% one way, towards the door,other way is fine.
my concern is swinging pickup gets caught under door when its on decal and getting jammed permanently in that position,defeating the purpose.
May I suggest... Before you put it back on, I'd put some oil {something viscous to simulate what it's like on the track with braking & acceleration in it} & slosh it back & forth see if the trap door works properly 1st, make sure the pick up doesn't get hung up or keep the door from working properly 1st & foremost... if if does get in the way maybe even weld in a mechanical stop, so the swinging pick up cant even get that close, to the baffles trap door operating... I have a sneaky feeling/suspicion that metal pick-up will move faster than the oil & trap door does, because of it's weight/physics, I could be wrong thou... It looks really nice other than that, that would be my only thoughts/ideas... good luck either way
