Lugnut_66
When testing dwell on my 318 poly, the dwell does not change from the 30* spec when revved to 1500rpm with the vacuum advance disconnected.
The dwell does drop, from 30* to 20*, when revved to 1500 with the vacuum advance hooked up.
The factory manual simply states that the dwell should not vary more than two degrees up to 1500rpm with the vacuum advance disconnected. There is no specific mention of the dwell varying with vacuum hooked up.
Does it indicate a problem if the dwell does change, when revved, with vacuum hooked up?? Or is it normal??
