Confused here, Is this a 413 or 426 wedge
nomax
4:32 AM
South Jersey
Been sitting in my garage and want to get rid of it, But don't want to misrepresent it.
My question is, Is it a 413 or 426?
#1852029
Thanks fellas.
looks like a 1962- 413 high performance & truck
wait a minute, i looked on-line and it could be a 426 as well, now not sure
#1852029
Thanks fellas.
Where are you and how much do you want for it?
Should be a pad on the left front and top of the engine in front of the valley pan rail that says what it is....
If you don't see the numbers on the pad as mentioned by Cranky, look on the driver's side of the engine block, just below the exhaust headers under #1 and #3 spark plug locations, you will see the block casting numbers When you find this, post it on here, this will tell you what motor it is and the build date.
Thanks fellas,
I'll check when I get to the garage in a few days.
Bird had it right 413. Med duty truck or max perf......stamping will tell you which one
1/4 inch oil pickup.
