1968 Charger
The mechanic that installed my intake and carb ran the hose from the pcv valve into the external bowl vent.
He put a rubber cap on the pcv valve of the carb.
I assume I need to run the hose from the pcv on the valve cover to the pcv valve on the carb.
Do I just leave the external bowl vent open. (what does this vent do)
I'm also putting a Mopar breather cap in drivers side valve cover because he had it capped off.
Any help would be appreciated, comments, suggestions.
