name that part
james133
12:59 AM
new york
I have a 69 charger 440. the part is under the battery tray it looks like a round mini oil drum it has a hose coming out that runs up to the top of the engine along the fire wall then splits into 2 smaller hoses one connects to the top of the engine block the other is not connected at the moment.. trying to find out where that connects
after looking up headlight vacuum canister and seeing some pics an diagrams that what it was so now I need to know where to connect the hoses that go up to the fire wall go I
I'm guessing they eventually get to the headlight switch - possible to a T fitting first?
There is one big hose and two small ones. The large one eventually fed by the engine vacuum, the small ones go to the switch. One in to the canister, one out. then it goes to the passenger side, and then operates that unit.
