2059
- 10:37 PM
- May 4, 2012
- North Central Indiana
During the past couple short road trips I noticed my pcv valve cap had blown off the valve cover neck. Didn't think much of it, took it apart, spread the retainer spring and reinstalled. Well, the Sunday drive a couple weeks ago I got back to the shop and noticed that my oil filler cap on the other side was gone (it was laying on the header) AND the pcv valve cap had blown off. SOOOO... ordered an evac kit from Summit and installed it yesterday afternoon. First; I know your supposed to install near the primary tubes in the collector. I wasn't going to cut into and weld on polished, ceramic headers. Second; i didn't install the tubes with the cut that way. Just pointing at the entry point. Third; i don't weld enough to be really good at it but it works with a little grinding. Lastly; I connected the elbows to the caps that way so I don't have ANY chance of a nut coming loose, inside the cap, on the elbow and causing grief. We'll see how this performs and if I like it.
3 hours later; test drive. can't say I noticed a difference however; no blown off caps and it didn't appear to have sucked any significant amount through the tubes.
