Replace the amp meter with a voltage meter or by pass the system.... go to mad electrical on the web.... the amp meter system is #1 fire starter in mopar stuff. The operation of the turn signal showing a huge movement on the meter = the sodder has come loose and any fiddling you do will only loosen it up more.... you can have the amp gauge 're sodderd but it's still a flawed system that should be eliminated...
Shannon @ Redline redid the amp gauge when restoring the rest of the dash. He added more solder and told me it was alot better than when new. Although he does convert many ammeters to volt meters, he assured me I would be fine with all new wiring and nothing added to the stock system (like a high amp stereo). I have read the mad electrical upgrade, and maybe will consider it in the future if I can't figure this out.
What are your measure on the charging side? The reason I asked with signal on & pulsating ammeter( Putting another load on system)...to help narrow down whether you had a charging system problem.
Also the main wiring harass splice gives power to Ignition switch, Head lights, dimmer switch, fuse box....the problem could lie there......
I'm out of town for a few days so wont be able to take any readings till I get back. I thought about that splice also, but the ammeter doesn't bounce when the headlights or blower fan is turned on. It seems to only be the directional, brake, and reverse light circuit. What/where would be the common factor with these circuits that I am missing? Turn signal switch? That is new also and anytime I've seen that fail, something doesn't light up.
