best rollercam set up for streatable 440 6 pack drag car...currently 509/292
saludora
9:31 PM
idaho
Looking to switch to a roller setup and wondering what a good ...leave someone sitting there wondering wtf just happened roller cam with a 6 pack setup you recommend
roller cam requires machining the cam bearing slots in block doesn't it?
Are you looking at a hyd roller or solid roller?
I have a hyd roller 516/536 230/ 242 at 50 on a 112
with rollers and push rods if interested
I looking to switch to solid roller for new short stroke / high rpm build
would i have to change pistons or do more mods for that setup?or will it clear stock tolerances.
Would need to check valve guide clearance on the exhast
This was bought from a buddy running 440 with dual carbs
Thats why the lsa is on 112
Better vacum for carbs and brakes
He went to stroker and I bought it
now im going small stroke high rpm motor
This was a custom cut from comp cams
Check out comps catalog under hyd roller 280
